I would appreciate any helpful critiques.
Wind conditions were 10 knots gusting to 17-18. My boat needs to reef at 15. It doesn't have a traveler and I don't have adjustable fair leads so I can't reef the jib safely on the furler system (the manf recommends against it with no adjustable cars because the furler will lift up).
Anyway, this means I reef early and my boat has one single large reef.
The boat is a fractional set up and is a B&R rig so there's no backstay. Also, I don't have a Cunningham.
What I do have is the main sheet, halyard and an outhaul (reef line in this set up). One question I have is if the edge of the leech is okay? I would get some flutter when a gust would blow. It has a leech line but I don't have a cleat or any way to secure the tension I might use.
The wind was a bit squirrely otherwise I would have gotten a pic with the jib. The gusts would come from a different direction. i was sailing close hauled and the gusts had a lot of turbulence ahead of them or something. The sails would luff and if you bear off to fill your sails, the gust would suddenly hit your beam. Due to the shape of the lake, many were sailing close hauled and many were having trouble with this and would round up. I learned to just wait out the turbulence and head up just a little so we could ride the gust. It was strange. Anyone with experience like that? Normally you can get a nice reach across the lake so the turbulence doesn't blow you down I guess?
