we replaced our 9/32nds uppers, headstay, backstay and 1/4 lowers and cutter/inner forestay with 5/32nds. What would be a suggested begining tension for this setup with the new shrouds having a higher breaking load.
After rereading your post, i must modify what i said earlier... accordint to what you wrote it would seem you went DOWN in rigging size.... not sure what to say about that other than you have weakened the rigging...we replaced our 9/32nds uppers, headstay, backstay and 1/4 lowers and cutter/inner forestay with 5/32nds. What would be a suggested begining tension for this setup with the new shrouds having a higher breaking load.
I would love to have a Loos Scale. But on the West Coast we don't need to take down the mast every winter and put up again every spring. And the guages from what I remember are somewhat pricey. Particularly for the models needed to accommodate larger diameter wire.I agree with Claude. The Loos Scale is probably one of the wisest investments you can make for boat. Not only for proper "dockside" tension, but once you get the tuning just right (performance-wise) you can make a note of the tensions and repeat the settings every year.
Loosening the rigging so the boat an relax between uses is not conducive to a sound and tight boat.... the allowed flexing is not good for it....One thing we do is to loosen the back stay to where it is floppy to unload the boat when we are not using it.
I suppose if you have a weak and unsupported hull it can bend into a banana... if the hull is strong, the liner and bulkheads tabbed properly and the deck is sound, the hull should be more like a large fiberglass football... and nearly impervious to distortion.... the boat is designed to withstand a constant load, but loosening and tightening causes stress...I have to respectfully dissagree with Centerline. Leaving a rig loaded, will in time bend the boat into a banana. Many boats from Thistles to two tonners are built with ways to unload the boat between hard sailing. Fiberglass will and does take a "set". There is a reason that they make backstay adjusters and hyfield levers.
You will now have a 'conundrum' of head sail shaping errors - principally on the headsail. Long winded diatribe follows:we replaced our 9/32nds uppers, headstay, backstay and 1/4 lowers and cutter/inner forestay with 5/32nds. What would be a suggested begining tension for this setup with the new shrouds having a higher breaking load.
