Well since you asked, I'll give my opinion. I put a composting head into an O'Day 26. I will see if I can find a picture of that installation. But I had to use the Vbirth, which we used as a storage area, and put it immediately aft and facing aft of the birth. It would not fit in the area built for the Porta potty on that boat. It was not pretty, and I had to keep the entrance to the head area closed, but it work for us.OK, where are the composter folks? We have a marine head on our boat, but if we didn't already, I'd put in a C-head or one of the other composters. I considered taking out our marine head this year and swapping to one of these, but I'm going to go with the known entity for now, and just replace the hoses. Ours has a 10 gal tank, and that's small enough that you don't get too many days between pumpouts when you're cruising. I like the idea of not having to worry about it with one of the composters, but I've never used one, and there are always some compromises whatever system you use. I've used the wag bag setups before, and would again in a pinch, but they aren't pleasant.
When we purchased and Moved a board full-time our Island packet 31 she had head issues. I decided to remove all that complicated and smelly gear and install the same composting head in the Island packet. The holding tank on this boat was completely in adequate given the fact that you must flush the pipes out with water or they will soon begin to stink. So when I did the install it opened up the old locker for the holding tank as well as got rid of all that stinky pipe. I did leave the macerator and pump out line in so that I can reinstall the head when we choose to sell the boat.
With that as background let me discuss the composting toilet in particular. First of all, once you get biologically balanced which takes about six weeks, it works beautifully. I certainly would not go back and install a regular toilet. For the nature's head, which we have, it takes a space 23 x 23". And the width is a little tight. 25 inches width would be better. But absolutely not less than 23 x 23. Part of that width involves the elbow for the vent pipe and being able to get your hand down on the side to crank the wheel which mixes the compost after each use. Once it is balanced and as long as you keep the little filter for the vent pipe clean there is almost no odor. In fact I would say no odor when things are working correctly. Certainly much less than we experienced with the traditional sailboat head. The urinal must be emptied daily. We simply pour the urine down the sink drain.. The urine is separated from the stool which keeps the compost from stinking. The compost material itself has not been even partially had to be removed over the past several months. Yes that's right several months. The only reason to remove compost periodically is that, as it becomes dense, it becomes more difficult to turn with the crank. I guess almost all of the bulk of the compost is eaten by the bacteria.
The only reason I can think of not to use a composting head is the space you need.. It takes more room for a composting head because of the venting and crank than a traditional sailboat head. Best luck! Keith
