Need advice to repair a broken main halyard shackle.
I have a wire to rope halyard. The shackle is attached to the wire rope with a swaged ball. The spring loaded twist lock pin completely fell out while I was rigging the sail and sank. I made a temporary repair using a clevis pin secured with a safety ring AKA ”Ring Ding.” Not sure why the twist lock pin fell through the lead hole (could be 41 years old?). At any rate, I would like to get the halyard back in shape – e.g. quick connect and quick release. Your advice please:
1. Any idea if there is a replacement pin option to return the shackle to its former function as a quick connect\release fitting?
2. What about adding a permanent pin to the shackle and fitting it with another type of shackle (snap shackle, key shackle, etc)? My concern with this option is it functionally lengthens the halyard by a couple of inches…
3. Remove the swage ball, replace the shackle and replace the swage ball. Only issue here is that I don’t have the tools to swage that ball on the wire rope. Is the original 1973 design even the best now or is there a better option if I remove the broken shackle?
Any advice you have is welcome.
