I'm looking at starting the alt bracket upgrade task for my M-18.
However, upon further investigation, I've inadvertently discovered that all of the notorious failures have been on the M25.
I know all the "better safe than sorry" ideology, of which I'm an advocate, but I'm not sure that I should delve into an upgrade that may be wholly unneeded.
The apparatus is sturdy. The belt is properly fit and aligned. There's no sign of fatigue. And the engine is 30 years old with 1,200 hours.
3 things:
1. Is there even 1 documented failure on an M-18 with the stock alternator?
2. Which part of the bracket fails? The solid portion of the lower bracket is also attached to the front of the heat exchanger as well as the timing case, so I can't physically figure out how the alternator can drop down to contact the oil filter, unless it's this heat-exchanger attachment that breaks.
3. The manual says 55 amp alt, but others says it's a 35 amp. Can someone clarify?
Thank you
3 things:
Thank you
