I know that this is a subject that comes up from time to time but I am still trying to figure out the voodoo science to calculate my daily power needs on my boat.
If I am typically cruising for 8 hours a day, on a good day I may run my outboard with a 6amp alternator for 1 hour (longer on days with no wind).
My power consumption is the tiller pilot (I calculate between use and standby it will consume about 27 amps per day), the Garmin 441s (I calculate 5.76 amps per day), and the stereo (about 20 amps per day). This is running them for 8 hours.
Total power consumption for these devices would be around 52.64 amps per day, according to my calculations.
Does this sound right?
According to my other calculations, I put about 1 amp back for the 5 watt solar panel and 6 amps for the hour of using the outboard. That would be only 7 amps replaced.
If this is the case I am going to need a pretty large solar panel, eventually, to keep the batteries up if I am cruising .
Are my calculations off a bit?
