If it's the ceiling fixture - you can twist the lens slightly and it'll drop out (leaving the base fixture in tact) You can replace with a 5 or 6 array LED. Not sure about your concern of 'danger' LEDs are basically a simple replacement - the biggest question is around color - bright white or warm white. If you do replace you'll notice longer life and cooler fixtures.Is it true that there is some dangers to swapping out bulbs?? How do I take overhead light off without damaging fixture?
Thanks. Heard of fire danger, maybe I shouldn't believe everything I hearIf it's the ceiling fixture - you can twist the lens slightly and it'll drop out (leaving the base fixture in tact) You can replace with a 5 or 6 array LED. Not sure about your concern of 'danger' LEDs are basically a simple replacement - the biggest question is around color - bright white or warm white. If you do replace you'll notice longer life and cooler fixtures.
+1 on marinebeam.Avoid problems by buying quality replacements. I replaced all the cabin bulbs on our 331 with LEDs from marinebeam.com Excellent quality, nice light, no radio interference. You tend to get what you pay for in the LED world.
