Help Identify this model
Jan 11, 2005
15
Converse 25 Fresno, CA
(1963 converse)
Hi, can anyone help identify this model of sailboat? I believe its approx a 24'.
Thank you
Picked her up today. She is a 1963 converse. Sailed Monterey bay until 7 years ago, and was then parked for last 7 years.
5
Pearson/Hunter P39 Sloop & 25'Chrubini Yankeetown, FL
Looks like an Early '70's either 23 or 25' MacGregor Venture? Not positive as the last one owned was storm damaged and once discovered was going to cost more than after repaired value, was cut up.
HTH,
-M
(PS: Check Your Transom...top left side, for H.I.N.[not federally req'd until 1972] & see if the SN starts w/"MAC")
Nov 6, 2006
10,129
I agree about the HIN , I think that there has been some customization. The fixed cabin ports have been filled with wood and opening ports installed. I think that the bowsprit is not original, just from the way it looks.
Jan 11, 2005
15
1963 Converse. Got her home yesterday. What a trip. Lost a wheel bearing, ouch. But 3 hrs later was back on the road. Will post pics later today.
Jun 19, 2004
512
Catalina 387 Hull # 24 Port Charlotte, Florida
Good luck with your new venture cudamank; I'm sure that you are going to have lots of fun with this. Too bad about the bearing but at least you made it safe. I'll be looking forward to hearing about your going through this boat and getting it in the water and sailing it. Good luck and congrats.
Jan 11, 2005
15
Thank you!
Thought I would post an update on what I have found on "Dancer"
Built in 1963(4) Hull number 1003.
Built by the Converse Boat and Yacht Inc
Santa Barbara, CA.
LOA 22'6"
LWL 19'9"
Beam 7'10"
Draft 2'
Full keel
Rig Sloop
SA 257 ft2
HullSpeed 6.67 mph
3,319
Hull speed is a little high. It should be 5.98 knots with that waterline length.
It is a neat looking boat. It will probably be pretty good at gunkholing with that small draft.
Jan 11, 2005
15
Thank you! I'm trying to find out more info on the boat and the builder. It needs the cockpit seating rebuilt, so looking for any help or pointers in that direction.
