My Main Salon hatches are leaking on my 456. They are the Lewmar Coast S-10 type. Does anyone have a fix for this? I tightens the latches but to no avail.
Thanks for the information. What an incredibly informative web site. Just to be sure, is the article of Maine Sail that you suggested I read before working on plugging the leaks in my forward hatch entitled " Re-Bedding Deck Hardware With Bed-It Butyl Tape"?Brunt, I would start with the hatch. If water gets in there it may be coming out at you port light or hull joint. Also I would not use a permanent sealant like 5200 because you may need to replace the hatch at some time in the future. If silicon was used to bed the hatch in the past you are going to have a difficult time getting anything to "stick". "Maine Sail" is a regular contributor to this forum and had covered this at his Compass Marine website.
http://www.pbase.com/mainecruising/boat_projects
Beynt, I don't have your boat but have fought this battle recently. Do the hatches have aluminum frames or are they a thick plexiglass with hinges? (Mine are the latter and a pain! If the former you need to derermine of the leak is from around the frame or closing pieces. Most aluminum hatch manufacturers have seals you can replace like Lewmar etc.Thanks for the information. What an incredibly informative web site. Just to be sure, is the article of Maine Sail that you suggested I read before working on plugging the leaks in my forward hatch entitled " Re-Bedding Deck Hardware With Bed-It Butyl Tape"? In the same article, is Maine Sail advising that silicone not be used to run a bead around the cabin windows but to use a polysulfide such as Boat Life Life-Calk? I think he states that since the 3M 101 is no longer available that Boat Life Life-Calk the sole marine grade polysulfide. Am I understanding this part of Marine Sail's article correctly? Thanks for taking the time to response to my first email. I would appreciate very much getting your response to the two questions I raise in this email. Beynt
