H26, 12 volt cabin light lens removal?
abk
Aug 9, 2007
203
Hunter H 26 Somers Point, NJ
Had the boat 3 years and i need to replace a 12v bulb... So before I bugger up the fixture with a screwdriver and jamming who could tell me the proper way to remove the cover to replace the bulb... Also a bulb replacement part # would be cool also.
Thanks in advance...
ABK
Aug 3, 2010
150
Hunter 326 Charleston SC
If it's the same light that's on the right of the page 2.5 " white bezel. gently pry under the edges of the ring and it will pop off. be ready to catch the glass lens as it's not secured to the bezel.
abk
Aug 9, 2007
203
Cabin light lens removal
Never saw the
Photo. I did pry out the plastic lens as high directed. It worked. The bulb was loose. Thanks.
Sep 25, 1999
600
Hunter 23.5 Indian Lake
bulb removal
Never saw the
Did your lense rotate to turn the lilght on and off? If so which part did you pry on ? Mine is a two piece lense .
abk
Aug 9, 2007
203
It didn't rotate it had a switch. But I was able to pry it out with a screwdriver. Thank you for posting
Aug 31, 2013
62
Hunter 26 Saylorville-Des Moines
I have a 1994 h26. My lens rotates CW to on and CCW to off, I think ... And you push up and turn just a bit further left (counter clockwise) at the same time to remove the lens.
