I'm looking for some troubleshooting advice pertaining to my Yanmar 3GM engine on my 1986 Hunter H34.
Last year I cleaned out & replaced the impeller and gasket on the raw water pump because the engine was overheating (see pictures). The impeller was destroyed (broke into small pieces). I thought the problem was fixed but now about 40 engine hours later I'm having the same problem. I replaced the impeller again but the engine continues to overheat. I confirmed the following;
- swam under the boat and cleared out the water intake seacock.
- Opened and shut the seacock valve and opened the relief valve and water flows out.
- Cleaned out the sea strainer
- Ran the engine with pump attached and then disconnected the water line running to the engine and no water was flowing.
- Blown air backward through the line connecting to the water pump inlet and the line was free and clear.
Questions;
- Is it possible that the pump is simply not creating enough suction. Possibly due to scarring along the inside walls of the pump?
- is the sea strainer a possible problem and should I replace it with a modern style?
- if I do replace the pump assembly should I replace it with the OEM or is there a better alternative?
- should I flush out the heat exchanger and if so how could I do that? It appears to me that I would disconnect day water hose and blow out the line in the same direction that the water pump flows or should I go in reverse?
- I'm aware of the two different pump styles based on the year. Mind is the one with a paper gasket and a pin that holds the impeller in place. the other style appears to have a screw through the shaft of the impeller. Is that a better alternative?
Assumptions:
- My best guess is the pump is running dry which causes the impeller to overheat and fails. I don't yet know why the pump is running dry.
Questions;
Assumptions:
