Spinnaker tack attachment
May 30, 2014
27
Catalina 310 Apollo Beach
The prior owner put an attachment point on the anchor roller. The anchor line can chafe on it, so I am reluctant to do the same. Where do you attach the tack?
Eric
Apr 11, 2012
324
Cataina 400 MK II Santa Cruz
Paul,
That's quite interesting. What brand of furler is that? Is it a top down furler? Are you able to use the jib furler when it is up, or do you take it down before using the jib furler?
I've just gotten an aysemetrical spinnaker (with a sock) and I might want to go towards a furler at some point.
Thanks,
Scotty
Catalina 320 Dana Point
I use a small block on the tack line which is shackled to the bail, tack line is secured to the foredeck cleat. Usually used in conjunction with an ATN Tacker I have some ability to adjust the tack up and down while keeping it close to the centerline, you can always adjust up but getting it down can take some muscle in a stiff breeze. I usually "blow" (release) it from the tacker when trying to carry the spin very deep downwind.
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
Paul,
Thanks,
Scotty
Brand....http://www.youtube.com/watch?v=1LrZYadbbc4
Top down
Are you able to use the jib furler when it is up ....... YES
paulj :troll:
