Tonight I took out my house battery to exchange it in the morning for a new one. I turned off the house battery switch, left starter battery on and turned on the shore power. After a couple of hours, I lost DC power completely. What do I need to look for? The battery shows 12.5 volts with a multimeter.
when you say you lost "DC power completely", does this mean you cant start the engine also or that you only lost power and dont have DC lighting in the house/cabin?....
the start battery should be seperated from the house, so removing the house batt will kill the house circuit, UNLESS you either have the battery switch turned to "combine" or you have a converter or charger working on AC power and converting the AC to DC...
look for a loose ground.... and im assuming you do have an converter/charger so its very possible you blew a fuse for the converter/charger...
you should have more than 12.5 volts at the battery if the converter/charger is working....
it kinda tough to tell you where to look without knowing what components you actually have installed....
