New Member/Daysailer question
dnv
Aug 3, 2014
2
AMF Puffer Terre Haute, IN
I am a new member to the group. I have owned several small sailboats including the Oday Javelin which I sold years ago. I now own a AMF Puffer but want something bigger. The Daysailer is what I'm interested in. My question is, what is the weight of the centerboard? The Javelin centerboard weighed 49 lbs. I would think the Daysailer would be the same.? Thanks
Catalina 310 278 Lyndeborough NH
The Daysailer literature says the centerboard is fiberglass. It should weight about 50 lbs or less.
May 17, 2011
76
Oday Daysailer II, Rhodes 19, Mariner 2+2 Dripping Springs
As I recall, the centerboard is either 21 or 27 lbs. Always forget. It is made of fiberglass as is the rudder blade. Check out the Day Sailer forum at http://www.daysailer.org Someone there will be able to tell you exactly what the weight is.
I have a Day Sailer II. It is a good boat. The Day Sailer I sails a little faster than the DS2.
John
Jun 2, 2004
1,957
Oday Day Sailer Wareham, MA
Day Sailer Class specs say the CB must weigh less than 25#, but I think mine is a bit more (Not a problem, I don't race).
The DS CB is fiberglass, unballasted, and on hte DS II and DS III it is raised and lowered by a pair of lines (1 pulls CB up, the other pulls it down) the DS I and hte DS IV use a bronze lever on the side of hte CB trunk to raise/lower the CB. The DS IV is the one built starting in 1991 by SUNFISH-LASER and now built by Cape Cod Shipbuilding. The DS II and DS III have theoretically self-bailing cockpits even at rest. they also have lockable cuddys. The DS I and DS IV have deeper, but not self-bailing cockpits. The cuddy on hte DS I is totally open to the cockpit, the DS IV has a bulkhead sealing the aft end of the cuddy with a small, watertight hatch for access (CCSB has enlarged that hatch, but it is still not as open as on hte DS II and III).
Basically, in hull design, the DS is a bigger (mostly longer) version of the Javelin with the addition of a cuddy.
May 17, 2011
76
I just looked at the measurement certificate for the Day Sailers that race and it says the centerboard can not be more than 25 pounds.
John
My O'Day 19 centerboard weighs 53 lbs. The 25 lbs stated for the Day Sailer would be appropriate.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
I'm wondering why the weight of the centerboard is even a question? Shouldn't need to pull it for anything. And it's not a swing keel needed for ballast - just weighted so it has negative buoyancy…
dnv
Aug 3, 2014
2
Thanks everybody who responded/answered my question
