De-rigging/Rigging ODAY 192
NateK
3
My ODAY 192 is docked in Mashpee, MA (Cape Cod). I am looking for a referral to a person in
the cape cod area that can de-rig and rig an ODAY192. Much thanks for anyone who can
help me here.
Pat
Jun 7, 2004
1,250
I would call Rudy Nickerson at D & R Marine in Assonet, MA. He should be able to help you or know who can...Good Luck, Patrick in Wichita
Catalina 310 278 Lyndeborough NH
help me here.
D&R Marine is Rudy's company.
This is the link to the O'Day 192 parts including the standing/running rigging.
http://www.drmarine.com/categories.asp?cat=279
My O'Day 19 had its mast/boom/rigging changed before I got it. The mast parts are not the same as the standard O'Day parts should be. The O'Day 19/192 share the same mast and boom extrusion cross-sections as the Rhodes 19.
Jun 2, 2004
1,943
Oday Day Sailer Wareham, MA
I would think any boatyard in the area that is familar with sailboats could unstep and restep the mast for you...... but for a price! Figure about 1 hour of labor each way (won't take that long, but they usually charge by the full hour, and boatyards charge $50-90 per hour! OUCH! The 192, being a trailerable boat has a very easy to handle mast, I'd do it myself or get a friend or two to help instead of paying an expensive boatyard to do the work. If you really want an O'DAY expert who is semi-local, give Arey's Pond Boatyard in Orleans a call, they were one of the biggest O'DAY dealers (in sales) for the entire history of O'DAY.
help me here.
Are you asking for assistance in stepping and un-stepping the mast plus the associated items?
If so, the process is simple enough. The mast can be hefted up in place.
When raising the mast on my O'Day 19:
• attach the side shrouds and back stay
• attach the jib halyard to a shackle on the bow stem fitting (leaving the forward hole open for the forestay pin)
• support the mast at the stern raising it up about 4-6 feet up from the cockpit deck
• slide the mast backwards until you can attach the rear pin/bolt for the tabernacle hinge
At this point you need to lift the mast. I'm 62 and can do it myself. I lift the mast while using the jib halyard running through the mast cleat to keep the mast at the level I have hoisted it. If no shrouds get tangled (they often do), I can lift mine up and insert the forestay pin in about 2 minutes.
For the first time (or if you are not comfortable of lifting up to 50 lbs), have 2 or 3 friends assist by holding the main and jib halyard ends (cleat off the other end at the mast base). These people will keep the mast from swinging side-to-side AND help raise the mast. The extra hands will be helpful if the shrouds need any adjustments. Once the mast is almost vertical, it is very stable.
On a larger boat I use a gin-pole with the mainsheet blocks for mechanical advantage. I attach a bridle on each side to keep the mast and gin-pole from swaying side to side.
Oct 4, 2012
2
ODay 192 Falmouth
NateK, I'm in Falmouth with a 192 I need help with. Perhaps we can assist each other.
