How deep can I set the machine screw head on a single loop teak handhold?
Put another way, can I drill deep into the handhold so the screw head is below the loop, about 1" above the bottom of the standoff part of the handhold?
I drilled the holes in two handholds and now I'm worrying the standoff portion of the handhold might split when someone puts weight on it.
The line in the photo shows the approximate depth of the screw heads.
I chose the machine screw so I could keep the teak bung at 1/2". I can get longer screws so the head would be closer to the top of the handhold and in the same grain as the loop but I need to order them. And now since I already drilled the handholds I have, I would need new handholds.
Do I start over or go ahead with what I have?
