Applying the Decal for a New Name
Jul 30, 2013
56
Hughes 25 Burlington
I have a new name to put on the transom but boat is in the water. Any suggestions on how to do it?
Apr 6, 2014
51
Hunter 240 Navarre
If it is a typical boat name vinyl sticker, like the sort sold by Boat US among others, it's a pretty easy job with tape to hold it in position and then peel off.
KD3PC
1,069
boatless rainbow Callao, VA
soapy water and some tape, you should be good. I did most of mine from the water, sitting in a bowline, the wife helped and stood by just in case.
A dinghy helps, or if you can tie off to the transient dock or a T head for an hour or so at your marina.
Jul 30, 2013
56
the decal
My boat is in about 8 feet of water so no standing in it . Getting a row boat on a calm day may work. I have a ceiling over my motor so it would be awkward to lay across there.
-na -NA Anywhere USA
One thing to include is a plastic scraper to help get the soapy water out and air pockets as well. Include several paper towels.
Hunter 29.5 Gloucester, VA
If in a marina with floating docks you can back in, or if close enough at high tide on fixed docks.
Jul 30, 2013
56
I do have floating docks and thought about sitting there to do it but if anyone walks by, then I go for a ride. Still, may try that.
We put ours on the transom, floating docks. What you may not yet realize, and it should come in the instructions, is that you have a short period of time to move it around before it sets. It is NOT like formica cement, for example. Good luck.
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
As GeorgiaBll said! Even though my slip was 7 feet deep, I took my boat to a nearby shallow area, stern to shore. I was able to safely work on the transom in knee-deep water. I was even able to remove my outboard this way. BrianW
Jun 14, 2011
277
Hunter 22 Fin Keel Lake Martin
That is what I was trying to suggest.... Guess I didn't use enough words! Thanks!
