labrador current
Jul 6, 2014
4
Siedelmann S24 Chicamacomico
hey, I'm picking up a 24' siedelman fixed keel from Forked River, NJ and headed to the Pamlico Sound this weekend. My buddy wants to take the Labrador current to Oregon Inlet. has anyone gone this way?
Nov 6, 2006
10,253
Labrador Current? Is that the name of an express locomotive that ya ship the boat on? That trip is 6 days minimum one way on water..?? Not gonna make in in a weekend.
Gunni
Mar 16, 2010
5,937
You aren't riding the Labrador unless you plan to make a stop in Ireland:) Down the coast with an option to get out of the ocean-up the Delaware bay, down the C&D and into the InterCoastal Waterway. You need to do that at Hampton Roads, VA in any case because you DO NOT want to be shooting Oregon Inlet or Ocracoke Inlet in a new-to-you boat. Enter the Pamlico via the ditch and the Neuse R.. Suggest a careful chart study.
Jul 6, 2014
4
that's what eveyone else has said i think i'm more looking for ways to get him not to keep asking about it worried i'll wake up in the middle of the atlantic
Gunni
Mar 16, 2010
5,937
If you do it right you will be inside the Gulf Stream the whole way to Cape Charles possibly riding a southern eddy (and dodging shrimpers). Nice trip.
RichH
Feb 14, 2005
4,773
Remnants of the south setting Labrador Current .... counter current to the Gulf Stream can be found quite close to the NJ surf line. Usually what is found is 'break-away' wandering eddies from the GulfStream that can come in close to the surf.
The predominant current along close to land off of NJ is 'south-setting'; but not always. There is a 'dividing line' between N and S currents at Barnegat Inlet. South of Barnegat the predominant current is usually south setting; and vice versa.
If its colder water - probably from the remnants of the Labrador counter current. If its ~80°F its probably an eddy current from the GS ... and can go in either rotational direction.
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
Reports indicate that the water is still in the 60's along northern NJ beaches (north of Barnegat, anyway)
You can find current water temps here:
http://www.nodc.noaa.gov/dsdt/cwtg/catl_tmap.html
Although there aren't enough stations to really get the picture.
From the weather.gov website you can go to the PORTS portal and get a graphical water temp. map but that portal doesn't work for me about half the time. Guess I shouldn't have filled out that survey (They asked). But this is the URL:
http://tidesandcurrents.noaa.gov/ports.html
We used to fish in the ocean south of LI and you can catch anything there that you could in the Keys if you get into Gulf Stream eddies. On your way back we used to go through large areas of lobster traps. Presumably set in the colder water brought down by the Labrador current. These intermingling eddies of warm and cold water is said to be why the sword fishing off Montauk is (Was) so good.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
We have been seeing a lot of strong westerlies in SE PA the past week. If they carry on out to NJ, and blow strongly off shore, then it blows the warm water out to sea, and allows deeper, cool water to "upwell" and create cold temps along the Jersey Shore.
I remember one year when my buddy and I were still kayak surfing a lot, we were wearing dry tops well into the summer while surfing, because the water just stayed cold due to the upwellings caused by strong off shores.
