best outlet for used sails
Jun 9, 2008
1,853
- -- -Bayfield
Bacon and Associates in Annapolis Md has to be one of the best sources. I have walked through their entire facility and they have thousands of sails from Opti's to Whitbread size boats. Very impressive display. They are nice people and easy to do business with. You have a trial period to use the sail to make sure it fits your needs and if it doesn't, you get a full refund. They also have a lot of new and used sailboat hardware, etc. On line, you can either find your boat or a range of sails to fit your dimensions.
Feb 15, 2022
16
morgan 38 built in 1976 38ft fruit cove florida
I’m the proud new owner of a Morgan 382 and it’s missing it’s main sail I need to know what size and type of main sail to look for can someone clue me in to what I need to find ? Thanks
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
I’m the proud new owner of a Morgan 382 and it’s missing it’s main sail I need to know what size and type of main sail to look for can someone clue me in to what I need to find ?.......
Congratulations on your new sailboat and welcome to the forum!!
Mainsail size is reportedly 293.63 sqft SailboatData.com - MORGAN 382 Sailboat. To accurately determine the mainsail size you will need to take measurements OR have a local sail loft do it to be sure it fits correctly. This article provides guidance on how to do this How to Measure for a New Mainsail - Precision Sails (precisionsailloft.com) .
Congrats on your new purchase.
Going from none to something sounds like a big improvement and feels like a good band-aide to let you go sailing.
I would encourage you to seek a new sail. One that can last you 7 plus years. You will avoid paying for the sail twice. If your car came to you with out an engine, would you be happy finding a used one with unknown value or would you buy a new one to make sure you can get to and from work.
A sail is the engine to your boat.
Just my two sense.
Feb 15, 2022
16
Thank you for the input and you are completely right and I’m trying to arrange funds to do so thanks again for your input .
421
Hunter 33 Metedeconk River
Not affiliated with them but if you are considering new sails, I would consider Precision. They were great to work with. My new main was not exactly right and they made it right...no questions, no hassles just good service.
Feb 21, 2008
421
I don't have the cost handy but I got the Tri Radials for the main and jib and the prices were significantly more reasonable than 3-4 other lofts that I priced.
Feb 15, 2022
16
I might have to settle with slightly Used main sail I’m on a low budget At the present .
dLj
Mar 23, 2017
5,178
I don't specifically know about the Morgan 382, but in other sailboats I've dealt with, you have to know what the sail track is rather exactly to know what sail slugs are needed to run properly up the sail track. Not all masts use the same sail slugs, even on the same boat.... Your neighors 382 may not have the same mast and sail track as your 382...
dj
