Ok guys thinking that I was being proactive this weekend. I flushed my 5411 (raw water cooling) with a vinegar water solution using a 5 gal bucket and a small pond pump. I let it circulate for 24 hours. I also checked the raw water pump and found a blade missing so I replaced it. Also replaced thermostat.. not new but one I had cleaned.
Problem...now it overheats. Discharge when there was a discharge from the exhaust looked muddy at first. Then I got to were there was very little discharge. Shut her down and let cool change thermostat again...long story short I tried several times and she would go past her running temp each time. Also noticed that the water in the raw water filter was now muddy looking, almost black.
I'm thinking a couple of possibilities right off the bat. That the flushing created a sludge inside the cooling chambers in the block or that the missing impeller blade is stuck somewhere.
My question is can I flush with high pressure water (dock hose) IF I first take out the thermostat, remove the hose from the top of the thermostat that goes to the exhaust T and plug that nipple? That way water will not fill the water lift muffler and back up into the cylinders'.
