83 27 foot Hunter Restore
Aug 2, 2012
3
Hunter 27’ Cherubini Racine, Wis
I am completing a restore on my 27' Hunter (tall mast) and am having problems with rigging my boom, specifically the out haul sheet and the reefing lines. Can someone help me with data of out haul sheet length, reefing lines length and diameter and a diagram of how both are rigged on the boom?
Jun 21, 2007
2,118
Hi dmiller:
It appears from looking at your Public Profile that you may have just joined the forum? If so welcome. The participants are always very helpful with excellent recounts of their experiences.
Your topic has come up numerous times with lots of good info already posted within the Cherubini forum ... even very recently (although for a Hunter Cherubini 33). Might I suggest that a good start might be that you spend a few moments and search the forums using the highest most search button in the menu section above.
Notwithstanding the info you find, you likely will need to make some of the determinations yourself. For instance, you might have a sail with the reef clews and tacks at different heights than Hunter's OEM sail. If so, then the OEM specs for the reefing lines won't be correct for you.
If you haven't already discovered, various original Hunter drawings of rigging and plumbing and electrical and also the original manuals have been downloaded into the forum. Being a long time since I needed because I have saved the pdf's directly to my computer, I don't remember how to find. And at the moment I can't do the sleuthing for you. But post again if you aren't successful at finding.
One item to mention is that original Hunter info about line diameter is now largely irrelevant since even in smaller diameters today's line technology permits greater strength and lower stretch with much smaller diameters than when our boats were made back in the late 1970's and early 80's. For an extreme instance, I would expect that today's 1/4" Amsteel would be stronger and with much lower stretch than was a typical 7/16" yacht braid in 1980. But still, and depending on how frequently the line is handled, usually more diameter than say 1/4" is needed for comfort and ability to grip in the hand. Also Amsteel for instance is slick and probably isn't the best choice for using through a rope clutch. If 3/8" (a guess) was originally specified by Hunter as the reefing line diameter for thew 27' model, then depending on the grade of line you choose, today 5/16" probably would easily be today's equivalent. But do the research yourself.
Mar 6, 2012
357
Hunter H33 (limited edition cabin top) Bayou Chico
hey now rardi, lol, op im selling a 80 27t right now, lived on it for two years, pm me with questions if you feel like it, ive been all through that boat and can answer anything that doesnt deal with the bow pulpit (never had one on the 27) or the inboard (boat had been converted to outboard power when i got it). so the reefing lines can be run with 5/16 but 3/8 personally feels better and fits fine in the kenyon sheaves on our booms, i would rig the whole boat in the cheapest 3/8 yacht braid you can find, use 3/8 regatta braid for the mainsheet tho since it will flow better thru the fairlead, also for the mainsheet i would really suggest moving from the floating a-frame setup to a dual-continuous line mainsheet system with snap shackles on the lower blocks.
pm me if you want my phone number and i can talk you thru a lot of it.
Aug 2, 2012
3
Hello rardiH36
Thank you for the guidance and information. You are correct I am new. I have owned my boat for 3 years and am just completing a restore. This is very helpful and I will look in this direction to solve my challenge. Thank you.
Hi dmiller:
Aug 2, 2012
3
Hello rufus1138,
Thank you for your direction, sounds like you have excellent personal experience with the 27 Hunter and I may give you a call if I can't see my way through it. Thank you.
