have a "120v" TV that has one of those power brick that outputs 12v to the TV. So the TV is acually a 12v TV. i've been runing it off an inverter, but that seems very inefficient.
What would happen i I wired the TV directly to the boat's 12v system? I'm gonna guess that it will work fine, as long as the input votable is nare 12v; however, the boats voltage can go up to 13 or 14v. How will this affect he TV?
Is there a magic box that will take the 11-15 input volts and output a steady 12v to the TV?
I don't want to continue with the inverter because the 10:1 ratio of amps through the inverter seems like a horrible waste, since the TV is a 12v TV (once i wire it directly.
How critical is it for the TV to get exactly 12v?
Thanks, getting this to work
Gotta keep the wife happy!
