Hello! This is my second year owning a 1979 Catalina 27. The boat needed some work when I bought it, and instead of working on it we've mostly been sailing! I live on Kootenay Lake so it's not too risky to put repairs on the back burner but the time has certainly come to take care of a few fairly major details.
I am interested in initiating discussion on these issues:
- The starboard cap shroud chainplate is pulling through it's bulkhead. It's a good thing the bolts keep the chainplate from being pulled through... Are there any kits or parts available for this fix?
- Both aft lower shroud chainplates are also compromised, although they dont look original - are there any recommended replacement parts for these?
- The forestay chainplate is pretty much blown out. Catalina Direct provides a stem fitting with rollers, are there any other options?
- It looks as though the cabintop is sunken around the base of the mast. There is a depression but it's not spongy nor does it make strange sounds when tapped, the compression post seems to be in good shape, and the interior of the cabintop isn't at all depressed. I plan on dropping the mast and investigating further but I was wondering if anyone else has seen this? What I think happened is a previous owner tried to get more life out of the shrouds by blocking up the mast? Can't quite figure out why - I checked the shroud with a loos and there is still threads to take up slack... I was thinking Catalina Direct's Mast Step would be a good idea?
- I am in dire need of a new main sheet block and traveler. Any recommendations?
- The bit of hardware that fastens the main sheet to the end of the boom - where can I find a new and improved one of those?
- I dont know if my boat is a standard or tall rig? An ancient Bill of Sale says hull # 4716 - does that mean anything?
