I have a 1980 O'Day 22 equipped with an aged but functional Raymarine ST30 BiData, speed and depth.
However the depth function is on its way out and I suspect the transducer is failing.
Question is this: the original transducer has a diameter of 42 mm but this item is hard to find and/or expensive. The replacement is 50 mm in diameter, easy to find and about half the price.
So how hard and what are the risks of enlarging the thru hull opening to accommodate the extra 8 mm?
Thanks.
Thanks.
