If I remember right from the one I used to have, there are two wood caps that hold cap off the edges of the hatch top held on with screws. I had to cut out the wood plugs capping off the screws. After reinstalling the caps you need to replug the screws and refinish
Good morning Dave,
Thanks for your help. To be sure I understand you correctly I've attached Photos 1 - 4 and Photo 1 is facing port on the boat.
So the 2 wooden caps you're referring to are they the wooden strips pictured in Photo 1? (Cap 1 is on the left side of the photograph Cap 2 is on the right side of photograph.)
Photo 2 is facing forward and is of Cap 1.
Photo 3 shows some of the screws holding Cap 1 in place on the edge of the plexiglass.
Photo 4 is of Cap 2 and facing aft.
So am I correct in my understanding that you're saying simply remove the screws in Cap 1 (Photo 3)?
Thanks.
