propane outboard
May 21, 2006
321
catalina 25, 30 montauk / manhattan
the outboard on the dinghy my marina provides is run on propane. don't know anything about them but what a great alternative for so many reasons. no dealing with gasoline, gummy carburetors. and super quiet.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
They have sold LEHR Propane outboards in our area for several years.
Here is a link:
http://golehr.com
I know very little about them however because I'm not in the market for one.
Ken
Mar 20, 2004
1,753
We have two of the 2.5HP Lehrs and they are fantastic - work well, no ethanol problems, and very reliable
Nov 9, 2008
1,338
Can anybody chime in on propane consumption? I fear I'll be in the market for a kicker in the future and I like the idea of propane, but how truly economical are they? I'd be looking at the 6hp or 9.9 hp.
Mar 20, 2004
1,753
Haven't tried the bigger ones but the 2.5 runs for a long time on the 1lb bottles. They come with a hose with a polnut fitting to take a standard grill tank too. Look on the Lehr website - they took an inflatable with (I think) the 6 out to Catalina and back as a demo-there was a video on the site
AJR4
May 23, 2011
10
Nauticat 32 Portland
Do you mind sharing the serial numbers of your two Lehr outboard motors? I have one (serial number ends in 00090) and it was great last year, but has been a nightmare this year. (Propane leaks, water in oil.) It has been extremely challenging to find anybody to work on it on Vancouver Island where I am cruising.
Mar 3, 2003
710
Hunter 356 Grand Rivers
I have the 5HP Lehr. I am running about 50% throttle and getting between 45 minutes to an hour off a 1 lb bottle. I haven't used it that much, maybe 3.5 to 4 hours so it is still in break in stage. I am very pleased with it. I have had a lot of problems with the ethanol with my previous outboard. There is a learning curve with this motor. You have to purge the air out of the line or you spend a lot of time trying to start it. The purge is easy, but they should put a purge button on the motor cowling. You have to take the cover off to purge it. Once purged, put the cover back on and reconnect the bottle and it starts on the first or second pull. It continues to start as long as the bottle is connected. Once you are finished for the day, you remove the bottle and depressurize the line. Next time you connect, you have to purge again. I highly recommend this motor, but Lehr could make a couple of improvements that would solve the purge issue.
Pearson 26W Marblehead
Propane outboard`s
I am looking for more info on propane outboards Are they available in Massachussetts how much do they weight Are they reliable.
Mar 20, 2004
1,753
Re: Propane outboard`s
the 2.5 weighs about 34lbs, the 5hp a little more. West marine sells them. We have 2 and they work very well, but you do have to purge as Jerry says. no ethanol problems, no stale gas issues! they do come with a polnut hose, so you can connect a larger tank if you need to - we just carry a spare 1lb bottle
