A couple of questions for those of you who have experience with the Catalina 30 universal 25hp heat exchanger. The one that just sprung a leak is a 2" and I am considering having a 3" installed. lst question- will there be any problem with the additional 1" diameter in the space the 2" came out of? 2nd-replacing the hoses is a given, are the hoses inside diameter the same as the 2" exchangers? 3rd-If they are different, what do you have to do in order to fit them on the engine? If I would have to change the fittings on the engine, it doesn't seem that it would be advantageous to change the size of the exchanger. We have had this Catalina for almost 7 years and this is the first problem with the exchanger. Any suggestion of anyone with the knowledge and/or experience of the aforementioned questions would be appreciated.
