The Admiral is irritated and when The Admiral is irritated I'm compelled to do something!
I'm referring to my 1993 Hunter 27
Is calking advisable around the base of the toilet housing which covers the plumbing from the seacock to the bowl to the holding tank?
The leak isn't coming from between the pump, which I replaced last year. and housing. It's only leaking from below the outflow plumbing and only after flushing.
I've tightened all 1/2" bolts.
Is there a seal that needs to be replaced which would require taking the bowl and housing off?
Working on the head....by far the worst maintenance task to deal with!
