So, after my 4th set of dinghy lights in 5 years, I've just about had it. Our lights spend most of their life in the dockbox and come out 6-8 times a season for the occasional evening dinghy run. They're generally not out in the rain, and I'm not flipping the dinghy and submerging the lights. Yet, seems every year that they are shorting out, getting wet/corroded on the inside. They're a flashlight (an expensive flashlight) with a fancy lense, how hard is it to make them fairly water resistant?
I've been struggling with the Aqua Signal portable lights, because they've essentially been all that was available. One of those replacement lights was actually sent out from Aqua Signal when I called and complained, and I actually talked to someone when the replacement that they sent out failed as well. But I shouldn't have to ship these back every season, they should work for more than a year.
So quick survey - what brand/model lights are you using for your dinghies? Are you happy with them? Would you buy them again? And what, if anything, do you do special in order to keep them working?
Thanks!
Thanks!
