Raymarine Chartplotter and Autopilot off by 180 Degrees?
Oct 24, 2011
278
Hunter Passage 450 Lake Lanier, GA
Recently I noticed that on my Raymarine autopilot my COG is off by 180 Degrees. Dead south is 0 Degrees and North is 180? Does anyone know what is going on? Could a setting have accidentally been changed on one of the units?
11,772
You need to re-swing the AP compass or make sure a tool bag or other metal object did not get placed to close to the fluxgate
11,772
Maine,
Could you please elaborate a bit. I am a non-techie:confused:
Was your autopilot ever set up? Calibrated to the boat?
In order to set up the AP one of the first steps is to calibrate or swing the fluxgate. This entails making numerous small circles with the boat in calm water with the AP in the setup screen until the "swing" takes. Sounds like you need to go through the set up procedure, it will be in the manual.....
In terms of tool bags etc. the fluxgate is like any other compass and can be drastically affected by proximity to ferrous metals.. Proper placement of the fluxgate to avoid magnetic interference is extremely critical..
Oct 24, 2011
278
Maine,
Thanks for the clarification...I replaced my wind display about a year ago and went through the procedure you described above. I am aware that any metal/magnetic objects in the vicinity of the unit can cause problems and I have ruled that out as the fluxgate is under the aft mattress. I am still not sure why this change suddenly occurred:confused:?
Jul 18, 2005
20
Hunter 35.5 Friday Harbor, WA
Sounds to me like an initial setup issue, maybe it lost its settings. I had the same issue with my Furuno radar. I'll bet it's just a setting, you might want to explore that before spending time spinning circles :)
Kermit
Jul 31, 2010
5,722
Lori,
I love the name of one of your races in your bio. Snooze n Cruise. I *might* be convinced to try that kind of racing.
Oh, sorry in advance for the thread hijack.
Oct 24, 2011
278
Lori,
Not a problem...Got it fixed this am with a re-calibration. Did have to make a few circles and it still wanted the 180 degree off setting so I manually set the offset to agree with my compass.
