I need to replace the 1.5" dump line from the head to the tank. It currently has the trident hose such as you find at west marine installed.... but it doesnt seem like it could be the best hose to use as its seems to check in spots and some of the older stuff (that I have since replaced) was actually perforated in spots due to the checking....
upon searching for a new water heater I have found that Raritan also makes sanitation hose.. they claim its the best hose available...
so,of all the brands that are available, what brand of hose would you install on your boat if you had the time and money????
when I bought the boat, I knew it had a leak in one of the hoses (a perforation). so after replacing all the hoses a couple months ago and thinking the problem was gone, I found it leaked only when it was full, and it wasnt the hoses.
so I removed the poly tank which was custom built for the space available, and found it had a faulty joint at the upper rear seam for about 18inches. I think this was due to a plugged vent line and when the tank got full it built too much pressure and eventually busted the seam....
so I removed the tank which took about 30 minutes, pressure washed it, then took it and had it re-welded.... so now I get to do the sanitation hose again and I want to install the longest lasting and least permeable hose I can get for the purpose...
