Stanchion angle
Sep 7, 2011
279
Hunter 1980 37c Illinois
Drifter came to me without much... do all 8 of the lifeline sanctions angle back or are some of them straight? Is there a lower cost supplier for these somewhere?
Thanks,
Rick
Johnb
Hunter 37-cutter Richmond CA
All of mine are straight except - the ones that have been bent. Extreme tension on the lifelines acts in the inward direction. Extreme tension can have various sources.......
I just made a post a couple of days back about how I have found it cost effective and easy to have stanchions repaired vs replaced. One I had done when I got my boat back in 2000 is still fine.
Feb 1, 2010
210
Hunter 33.5 El Dorado Lake, Kansas
I jest got one new and had the others rewelded and they were 11 degrees.
Hi Rick
Here is the correspondence I had, along with the measurements, when I replaced lifeline stanchions on my boat 3 years ago:
Jim, Cost is $106.00 ea + shipping. Give us a call if you'd like to order. Thanks, Mike
Mike Klaas / Tom Heering
White Water Marine Inc.
810-987-4837
This message originated from: http://www.whitewatermarineinc.com/contact.html
Sender: Jim Legere
Hi, had some hurricane damage when Earl visited two weeks ago. I am just now getting prices to fix everything. Can you please quote FOB Port Huron on Qty 3 of these stanchions for a 1983 Hunter 37 Cutter: Top "D"; Intermediate "I"; Base "Z"; InBd Angle 7 deg; Tube 1 inch; No Taper. Thanks for your help - look forward to placing an order and getting these fixed!
Best,
Jim Legere
Dec 2, 1999
15,184
The stanchions on the 37C are not flat as shown in the example. The oem ones have horizontal and verticle screws.
FredV
Oct 16, 2011
148
Hunter 37-cutter Philadelphia, PA
Try eBay
I needed one for my 37-C and found a pair of the identical stanchions on eBay for $20. I almost always check eBay first for anything I need for the boat.
Good luck!
Aug 23, 2009
361
Hunter 30 Middle River MD
I have two stanchions in my garage which were passed to me when I damaged two of mine unfortunately these were not a match for ours so I had ours rebuilt. These have a flange that goes over the toe rail. If anyone is interested they are yours either for pickup or you pay freight.
