Replacement plexiglass companionway sliding cover
Jun 14, 2011
277
Hunter 22 Fin Keel Lake Martin
Girlfriends Daughter knocked over my companion way sliding top and it shattered.
Where can I get a replacement?
May 6, 2012
303
Hunter 28.5 Jordan, ON
Adoption, or, wine and dine the girlfriend then wait 9 months and hope for the best.
Wait, never mind...
May 6, 2012
303
Okay, I see you haven't had much of a response yet.
I can't see what boat you have on my mobile device, but in any event, if you have to go to an aftermarket supplier then check with your local plastic sheet goods supplier(s), asking for a suitably sized piece of acrylic.
Good luck.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Just go to your local glass shop with it and they will cut you a new one. It will be flat stock though. Chief
-na -NA Anywhere USA
One good source are marine yards in their scrap pile and if you find a piece big enough to measure and cut, probably it will be cheaper. THat was one way I was able to find pieces much cheaper without having to purchase a whole sheet.
203
Nov 5, 2013
73
Hunter 22 1983 Lake Norman
I have worried about this guaranteed failure on my H22 every since I got it. I presently have a 2 inch crack that will eventually look just like yours.
I have seriously considered looking at replacement 'windows' for skylights.. I think there might be a fit there, and would not be surprised at all if that was not the original source.
A higher end building supply place, or the internet, might supply an answer. The arch in the companionway is going to severely limit how well a flat piece works. If you use a flat piece, I think you're going to end up building a frame that has the arch built into it and is 1.5 or so inches 'tall' to get over the entire arched portion of the hatch.
Mar 28, 2010
44
Hunter 23 El Dorado Lake, KS
This outfit may be able to help:http://www.lustercraft.com/. They are located in Wichita. Kansas. They sell all kinds of thickness of polycarbonate sheets. They cut it the size to order. Also might be a company that sells the stuff in your area as well.
Good Luck!
Jun 14, 2011
277
So far quotes have been 750-850 dollars... I didn't pay that for the boat!
Georgia Bill;
Again check with boat yards at the coast or at Lake Lanier to see if they have any scrap big enough that would work assuming you are in Georgia. As a dealer and to keep the price down, I had my contact boat yards and most of the time I found what was needed and did not have to buy a brand new sheet which can be costly.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
Select Plastics in Norwalk, CT. They are kinda the go-to for most people with any custom marine plastic portlight or hatch repair, at least on the east coast....
Nov 26, 2012
2,315
Lexan will not break as far as I know. That means that piece is Plexiglas and your local Glass shop will cut you a new one for maybe 50 bucks. It will be flat stock, but will be tinted though. Chief
Nov 6, 2006
10,152
I am just starting to collect parts to replace the one on my 34. I bought the 1/2" thick, light smoke tinted acrylic (plexiglass) from e-Street Plastics.. don't know how thick yours is.. they will cut a piece to size for you.
https://www.estreetplastics.com/Grey_Smoke_Plexiglass_2064_s/80.htm
It will be flat stock .. It is tough to find 1/2" thick stuff. My local plastics folks had none in stock.
EDIT: I see that flat stock will not work.. Only way I know would be to get a plastic shop to do it. They'll have to use the old slider to make a mold then heat- bend the acrylic to shape. Probably why you are getting such big quotes. An alternate would be to build a curved frame of wood or composite that would be curved on the bottom but accommodate a flat piece of plexi.
RE_Edit: OK I see a former poster suggested the frame.. The old slider can be glued together then supported in sand in a box.. then waxed and plaster-of-Paris poured into it to replicate the inside contour. That piece of plaster, once carefully removed from the original, will make a male mold .. A plastic shop would put a sheet of flat on top and controllably heat the whole thing and the flat sheet will drape onto the mold. Then the new part has to be finished .. labor intensive. .
2,315
Sorry, didn't notice flat stock will not work. Suggest redo whole system and eliminate the curved need. Chief
Aug 24, 2010
26
Hunter 22 Cape Vincent NY
I bought a piece of plexiglass at lowes and using the original wood built a new one
