P420 4jh3 rsw pump
May 1, 2014
4
Hunter 420 Fort Myers FL
Sea water pump on 2002 CC P420 with 4jh3e needs to be replaced. Pump is directly on motor mount & one bolt unremoveable because of mount. Assuming must remove mount, any suggestions? rebuild mount so can access easily in future?
Apr 22, 2001
497
Hunter 420 Norfolk, VA
My 2001 H420 has a Yanmar 4JH2 engine, ( not a 4JH3). You might want to double check which engine you have before you purchase a new raw water pump.
I have not had to replace mine, so I'm not sure about attachment.
Since the motor mounts are now 13-14 years old, it may be better to just get a new motor mount as well as water pump if it's impractical to remove existing pump from mount.
May 1, 2014
4
10 years later...I answered my own May 1 2014 this forum. I pulled motor mount, redesigned it, took it to a fine welder who took it apart & re-welded to my design. It fit back well, with a bit of adjustment and seawater pump now comes off & back on easily. Thx
1,813
Hunter 49 toronto
You might consider my 4JH impeller upgrade. That will be a great long term solution
