Building a fiberglass frame (PICS)
Jul 21, 2013
333
Searching for 1st sailing boat 27-28, 34-36 Channel Islands, Marina Del Rey
Hello,
I am building a fiberglass frame, 2" wide, it is actually a mold which will turn out to be a flat frame, pictured below. The purpose of the frame is to use as a guide.
If you look at the outer dimensions on the frame, 48" x 65", I am wondering how to stop it from flexing? I want it to maintain its firmness when laid down after it is built?
I am thinking about 3 layers of fiberglass cloth and a 1" square x 4' piece of wood (big store has dowels) as backing?
Gunni
Mar 16, 2010
5,937
Vacuum bag it on a sheet of laminate (formica).
Jul 21, 2013
333
I should have mentioned that I am not setup for vacuum bagging and have rudimentary methods of working. First time working with fiberglass, only 3 months experience. :)
Feb 17, 2006
5,274
I am not sure of the overall dimensions of the frame but if it were me, I would just leave it on a concrete floor and fiberglass the top of the frame. Then after setting up, I would flip over and do the other side. By then it should be firm enough not to flex. Or am I missing the concept of what you are trying to do?
Am I guessing this is a template to see why your deck does not fit properly?
Jul 21, 2013
333
Brian, you guessed correct. :D
The overall dimension is 48"x65".
I don't want to over do it but want to make sure the frame is stiff enough so that I can use it to check the level on my deck, grind the high spots and it should fit perfectly when I put it in.
The 2" wide dimension is the contact area and that is really all I need to check the contact surfaces. Imagine a picture frame, flat and 2" wide borders.
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
Put down heavy plastic! Or you will have a annoying bump in the middle of the garage floor...
Here is a link to a little fibreglass job I am doing right now. http://forums.macgregor.sailboatowners.com/showthread.php?t=161192
To keep it flat you need to keep it flat for a few days (like a week) after it sets up. Don't lean it against the wall or else...
Good luck.
Forgot to mention YouTube. boatworkstoday and search building a fibreglass mold.
Jul 21, 2013
333
Thanks for the tip @finding41 on keeping it flat.
