I have a 1975 30 hunter with bad valves.I want replace them with marelon seacocks.I would like any input anyone has on this issue.
as i read this in your last post, I want to suggest that you should never be seeing yellow brass on the hull of your boat anywhere, healthy or otherwise...John:
At my last haul-out several years ago, from underneath, spot scraping here-and-there revealed only healthy yellow brass.
I hope to see again nice yellow brass on the bottom side.
Centerline ... you are right. I started my post citing "bronze". Than in a moment of inattention, I typed "brass" later on. The fittings are "bronze". I do know that brass is a no-no for most boat applications.as i read this in your last post, I want to suggest that you should never be seeing yellow brass on the hull of your boat anywhere, healthy or otherwise...
bronze is good, brass is not.... and they do look different if you have ever seen both side by side.![]()
I caught that in your post, but for those who may be reading the thread and NOT know the difference, I thought I should make it clearCenterline ... you are right. I started my post citing "bronze". Than in a moment of inattention, I typed "brass" later on. The fittings are "bronze". I do know that brass is a no-no for most boat applications.
