Last season I could hear a creaking noise when moving the tiller. I knew the pintles
were a little loose, as was the tiller. That's what I figured it was.
Fast forward to today. I pulled off the pintles to inspect and rebed them and found a crack in the gell coat. I pulled out my festool ct 22and started sanding. The crack went all the way through the fiberglass, through the filler from what looks like a previous repair, into the foam center.
My initial take on this: fill back to the level of the inside of the lamination using epoxy and cell-o-fill. After that, replace the lamination with fiberglass and epoxy, brush on a thin layer of gell coat or paint.
Any thoughts? Buy a new rudder?
