I have a pretty good drip from the cold water pipe where it enters my hot water tank. It appears to be the connector on the plastic pipe. From the Hunter manual it seems the ring can be pushed in to release the connector, and open it up. Not sure what that would gain me ? Do they just need to be reset when this happens ? Cleaned up ? I have no experience with these obviously.
It seems I can only turn this water line off at the fresh water tank. So if I release the joint can I fix the leak ? What is the reason for the leak and the solution ?
I don't have any of these connectors with me and don't know how easy they would be to find in Marsh Harbour.
Any suggestions appreciated, Bob
