Thanks folks for commenting on my post, IPADS, GPS, VHF, etc. on 03/21/2014
Here is what I found:
GPS- Hisense Sero 7 LT 7" Tablet 4GB Memory Dual Core Refurbished
Walmart $79.99 . I like the 7" screen for old eyes. Is refurb OK? I must
find out if it is sunlight readable?
Depth Gage- still searching for one can see screen in daylight. Overtons has Garmin
Echo 100 #93356, $76.99.
Walmart has #200 Model# 010-00953-00 Sun Light Readable, $135.
VHF- Standard Horizon HX370S or HX290 Floating Hand Held VHF Radio $129.99
at Overton.com What is diff., about VHF and VHS ?
Compass- Ritchie Trek Flush Mount Compass with White Dial, Built in 12 Volt Green
NiteVu Lighting $49.99 at Overton. I like the white dial and night light. Does this plug into my boats 12 volt battery power with a cable ? I must check on that.
My 79 O'day 22 has a compass mounted outside on the cabin wall, will it need
to be reset or can it be? It seems to be fairly accurate. If this compass is good I
am thinking of mounting the new one on small base to use inside cabin.
Someone mentioned putting downloadable charts and print them for a 3 ring notebook if I understood correctly ? Would some one expand on this ?
David S
David S
