wind or solar
Sep 11, 2012
9
Hunter 26.5 Lubec
Thinking of adding a charging system to my 26.5 Hunter. my requirements are basic ,Radio, depth and speed. at this time we do not overnight on the boat. We sail her in Maine (Lubec). I need a steer on which would suit my needs best wind or solar charging. I use my engine very little about 4 hours a season, but want to keep by batteries topped up for when I need them, bilge pumps ect.. Any info is a help at this point. thanks Hickdog
Nov 26, 2008
1,970
Endeavour 42 Cruisin
I suspect winds are often light in the summer.
Days are definitely long in the summer.
Solar!
Jun 6, 2006
6,990
You would have to tell us your batter bank size (AH)
Also a little more on how you use the boat.
The tradeoff being deck space (solar) over wind speeds normally encountered during the use of the boat (wind)
I would tend to agree with gettinthere but deck space may be the determining factor.
Most cruisers use both for a lot of obvious reasons
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
I'd think a small solar panel would suit your needs. Much less maintenance (actually, little to none), and the wind turbine really needs someone to tend to it, more suited to live aboards.
Sep 11, 2012
9
Hunter 26.5 Lubec
Thanks for the post. as far as the battery bank we have one 12v Car size battery, don't know the amps off the top of my head.. I believe that solar will be the way to go.
Nov 14, 2013
200
Catalina 50 Seattle
Get a little digital charge controller to go with it. I had good luck with this little unit and it's <$35:
http://www.amazon.com/Sunforce-6003...r=8-3&keywords=sunforce+10A+charge+controller
I combined it with this 20W monocrystalline panel:
http://www.amazon.com/HQRP-Mono-cry...id=1395749908&sr=8-3&keywords=20W+solar+panel
and it worked great, even if it's all cheap Chinese stuff.
If you have the budget, ~$65, this little charge controller would be a good upgrade:
https://genasun.com/all-products/so.../for-lead/gv-4-pb-4a-solar-charge-controller/
11,767
In Lubec I can't imagine summer winds are any better then they are on Casco Bay. Solar wins in Maine and is also far more reliable.....
Feb 17, 2006
5,274
I use a 50w solar panel on my boat. I have measured mid-day with a current meter 2.29 amps. So given that 5 hours/day seems to be the norm, I am looking at 11.45 amps in good sun conditions. On my last outing, I ran radio, autopilot, and two GPS systems and the panel was giving a float charge to the battery. So basically I was just using the panel to run my electronics.
I say solar also.
cjm1
Jul 10, 2013
41
custom Herreshoff 33 sloop Lake Charlevoix
I have been using solar for 20 years (2 panels 20 w and 40 w). They have never let me down and they do get shaded at times. We have no high current drain items and use a digital volt meter to keep an eye on the batteries. Do use deep cycle batteries rather than car starting batteries. Wind gen is noisy and I am sure they come with maintenance issues.
