She's mine - New 37C owner
Feb 20, 2014
11
hunter cherubini 37 Kemah, TX
Okay, the survey got done, last minute jawing with previous owner, etc.
Two things stood out. The survey is very useful for me to know what to fix. It is also useful for negotiation with the current owner. Where it sucks is the insurance company. We had hell getting it insured for a reasonable amount. Had to tell one agent to take a hike. Then ran into a very nice guy. But they still are getting very dicky about the older boats. I have a feeling there will be a day when you will find it impossible to insure some of the classic plastic. What is curious about this is that I am much more confident about my 1982 Hunter than a current one. The boat came in above average on the survey!
Point two. We get moved on, are cleaning up, fixing some hatch dogs, filling up water tanks etc. We have a very productive three days, and it is time to button her up, and go back to the house. I lay down, and lift the floor panel off, and check the auto bilge pump. (I am a paranoid by nature). I have checked this beast twice, and the surveyor once. It will not come on. I jiggle the float, start shaking wires, and it comes on. And then a puff of smoke, and some burning insulation. And it will not work!
The pump comes on manually thru the breaker box. The float will not turn it on. SO a trip to West Marine, and I am putting on a new float with the crimp on butt joints. While I am doing this, the wire breaks 8 inches up. I get to checking it, and there is a 12 inch section with absolutely no integrity. When you peel the insulation back, there is literally orange dust in there. I have no idea hows the hell the pump was coming on to begin with. So new wire and it all works.
As a aside, the installer had not wired or ziptied the wires up out of the bilge. There was not a ton of water in it, even with it sitting, but it has been submerged. The prop was shot on survey, and I think it was due to the wire/bad connector leaking current into the water, and helping the electrolysis along.
So hours later, she is working, wires up out of the bilge, and we are on the road. There will be a ton to do, but I love this boat.
The more time I spend on her, the more I respect her. Cherubini was a helluva designer.
My previous ride was a Tayana 42 Vancouver center cockpit. I think I actually like the 37 better.
Blaise
Hunter 37-cutter Bradenton
Welcome to the group. You will have a lot to do, but it will all be worth it. It really is a great boat once you fix all the things Hunter cheaped out on. The boat is built like a tank and will take you anywhere. I am the senior owner in the group having bought Midnight Sun in 1978, and still learn things about the boat from my fellow owners. The boat sails better as a sloop.
Feb 20, 2014
11
Sloop Rig
The previous owner already had removed the cutter rig. She has a 150% on front, and this lady flies. I was impressed on the sea trial.
Feb 20, 2014
11
San Diego
Thanks Gary. I started sailing in San Diego. I used to fly out there twice a year to visit a Army buddy. He was in a sailing club, and then we took one out for a week to Catalina, and I was hooked. Maybe I can get this girl up to your neck of the woods. It would be the only way I could afford to live in Diego anymore. What are slips now a month?
Oct 27, 2011
154
Hunter 1980 Hunter 30 San Diego, Mission Bay
Wolfer -
Cool. I pay $370/mo for my Hunter. That's in Mission Bay. Slips in San Diego Harbor are a bit higher, I think.
Would be nice to see a 37 here.
Gary
Jun 2, 2004
5,802
Oh geez, not another H37 "sloop"! :)
Congratulations anyway.
Jun 2, 2004
5,802
Hunter Marine just posted six pictures of the H37C on Facebook including yours Blaise. One problem, they called them "Cheribinis".
Jul 21, 2013
333
Searching for 1st sailing boat 27-28, 34-36 Channel Islands, Marina Del Rey
Congratulations!
Need crew, PM me.
Need help fixing, PM me.
Post pictures of boat and all your projects.
Jun 5, 2010
1,123
Hunter 25 Burlington NJ
... Cherubini was a helluva designer.
Well duhh! LOL
Welcome to the crowd. (I won't report to Robert Perry-- NOT a fan of my dad-- what you said! :D)
Ed raises a good point for you. Do look into the recent/resurrected post about the loss of the outer headstay on a 37C for some valuable insights into the value of redundancy.
That said, after speaking with a friend who sailed a Bristol 32 yawl, to which he had fitted an inner forestay (for redundancy), across the Atlantic, I 'reengineered' my internal spinnaker-pole lift to function as an inner-jib halyard on Diana. This 'mod' includes tangs on the mast for the opportunity to attach a (detachable) inner forestay and running backstays as well.
'Redundancy is the byword of safety' --engineers' proverb.
Jun 5, 2010
1,123
Wolfer-- your bilge-pump hassle
I have the Johnson Marine solid-state float switch rather than the dodgy Rule flapper one. It
is a newer edition of the time-honored 'Water Witch' type. It has two sensors, close to the bottom, about 1-1/2" apart vertically. When they are both wet, the switch kicks on the pump. It does NOT break, jam, fail, or work only intermittently when there's dirt or grit. (However oil in the bilge kills it; that may be a good thing considering the alternative.) It goes for about $39.
I put the Rule 37 flapper one on eBay. ;)
[QUOTE="Wolfer69;on to begin with. So new wire and it all works. As a aside, the installer had not wired or ziptied the wires up out of the bilge. There was not a ton of water in it, even with it sitting, but it has been submerged. The prop was shot on survey, .[/QUOTE]
FYI mine came with a worn out Martec Two blade. After some moderately expensive experiments, we settled on a 17 inch Kiwi feathering prop. LOVE it !!
Mar 20, 2011
623
Hunter 31_83-87 New Orleans
Congratulations. The 37 C's are a great boat. Where in Kemah are you? I am in Seabrook marina on O dock. I have a 37 a couple of slips over. Lots of vintage hunters there. Hope to see you around.
Hunter 37C McCormick, SC
Congrat's , & good luck on the repairs. I still have mine as a cutter rig, but the boat did come with a 150 jib as well. My first sail impressed me too, she really took off. The others on this site have lots of suggestions and experience that I have both appreciated and used.
