where is he factory depth transducer?
Apr 19, 2011
456
Hunter 31 Seattle
I've traced the wire down to behind the engine but then runs into one of the "holes" that are under the fiberglass and im not sure where it leads to. I need to check near the strut bolts are located. Seems like a weird place to put it with the turbulence from the keel but what do I know.
Anyone trace it before?
Thanks again!
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
I don't know about your particular boat but...
...depth transducers should be forward of the keel so you know the depth where you are going, not where you have been. Have you looked under the floorboards forward of the keel?
Aug 23, 2011
94
Hunter 31 Georgetown, MD
Re: I don't know about your particular boat but...
Jared, my old Datamarine transducers are under a small step below the V bearth
Apr 19, 2011
456
Hunter 31 Seattle
I've got ones there also but its for speed. I think they might of got them backwards while installing at the factory.
I think the depth one is aft but in front of the prop by a few feet but haven't confirmed yet.
Nov 23, 2011
87
Hunter H31 Kent Island Yacht Club
I found the same issue - the previous owner thought that the transducers were bad - because I found three of them rolling around near the prop strut attachment point.
I had the back holed sealed up and ran the depth sensor forward to the paddle wheel through hull, near the holding tank in the bow. I use the GPS for a speed indicator
and depth finding. I hope that helps. I also had two of the gate valve through hulls replaced to the ball style seacocks at the engine cooling and the sink. It is a wise investment.
MN
Mar 20, 2011
624
Hunter 31_83-87 New Orleans
Mine is located aft of the engine near shaft and adjacent to the raw water intake sea clock. Accessible from port quarter berth by removing plywood access piece under cushion.
IanJ
Nov 7, 2008
152
Hunter 31 Port Royal, CA
Very coincidental with this post. My transducer has suddenly stopped working, and maybe someone can shed some light on it. At present it is showing two dashes instead of a reading, something it normally does when the depth is over 100 feet. I also have a 1984 Hunter 31, and suspect that, as earlier stated, the sensor is nearer the rear of the keel than the fore. Any ideas before I start tracing wires?
Apr 19, 2011
456
Hunter 31 Seattle
My depth gauge usually only did the dash dash thing over 240 ft.
Did you recently repaint the bottom? I noticed some issues with it after I did then it started working a few weeks later.
I suspect its next to the strut. Access through the aft port quarter berth if thats what you were asking.
I traced one of the wired to the starboard "dungeon" then down behind the built in battery box thought I haven't traced it farther than that.
IanJ
Nov 7, 2008
152
The bottom was painted a few months ago, and my diver said they had painted over it. He cleaned it off a few weeks ago, and no luck yet. Maybe I will give it a couple more weeks and hope for the best. Thanks though
Mar 20, 2011
624
Ian
If it's the original data marine unit suggest contacting DMI for troubleshooting. www.dmimarine.com. Phone 774-213-9744. I had them service both original knot and depth equip 2 years ago on my '84 and both are fine now (knock on wood)
IanJ
Nov 7, 2008
152
Ok, I think I have located transducer in head on starboard side in sump. It says " hand tighten" and is a black plastic fixture with a wire running into it. So is the glass cover you can see on the underside of the hull a permanent fixture, and this part unscrewable, or do I need to get the boat out of the water to remove this to service? Picture attached
1,450
Ian, unlike speed transducers, though-hull depth sounder transducers are generally permanent fixtures and you need to get the boat out of the water to remove them. Picture of yours makes me think that's the case. Good luck
Mar 20, 2011
624
Ian
That is the same as mine on the H31. Recently had to replace wood backing plate and had to pull the boat. I believe Claude is correct in that unlike the speedo there is no temp plug to put in its place. Suggest contacting Data Marine from my earlier post here and they can advise the best way to handle replacement.
IanJ
Nov 7, 2008
152
Thanks guys. Will follow your advice on this one. Very wary of holes in hulls!!
