Diesel tank has a leak
PDA1
Aug 19, 2013
18
Catalina 30 MkIII Tall rig In the water
I've got a Catalina 30 MkIII. The Diesel tank has a very tiny drip coming from it. The tank is 20 years old and holds 18 gallons.
I've seen the "epoxy/glue-repair" kits. I don't want to take the chance of the leak springing anew while underway. I've seen (on-line) some of the repairs jobs folks have done on their tanks and they are largely unimpressive and look downright stupid and scarey.
What would you recommend for repair? Re-weld?
A new tank?
If you suggest a new tank woul
7,695
Alden 50 Sarasota, Florida
Sounds like you don't want to find out at the worst possible time that it wasn't the only bad spot in the tank. Think of it as not a leak but the FIRST leak.
PDA1
Aug 19, 2013
18
Yes, that's what I figured would be the case.
Ok. So get a replacement.....where? Any ideas?
7,695
Can't help with a replacement but suggest you remove the old one first to avoid surprises with the new install logistics.
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
PDA1, your tank may have a label with the manufacturer of the tank. You could call that company and they might have or make a replacement. That's what I did on my 1990 recently.
PDA1
Aug 19, 2013
18
Doug, I found a photograph of the tank I took when I made a photographic detail of the boat. 'Thought I didn't have one.
It's an RDS (Perry, fla) model 51048.
Oh boy...now the fun's going to be getting it out! Ugh.
Oct 15, 2008
87
Catalina 30 Mexico
Been there, done that....welded, but not effective. CONTACT CATALINA! Picked up a new tank from Catalina, fit perfectly.
Jan 31, 2012
56
Catalina 30 mkIII Santa Barbara
I just replaced my leaking fuel tank of about the same age. Catalina Yachts has exact replacements. Catalina Direct also has aluminum replacements but when I pulled my tank I found that the end nearest the water heater was resting on 4 stainless bolts and electrolysis caused the leak. Still waiting to hear back from Catalina Yachts about this questionable factory install. I found a XLPE (plastic) tank that is 16 gals and fits reasonably well. Let me know if you find the same problem I did.
dj2210
Feb 4, 2012
337
Doug, I found a photograph of the tank I took when I made a photographic detail of the boat. 'Thought I didn't have one. It's an RDS (Perry, fla) model 51048. Oh boy...now the fun's going to be getting it out! Ugh.
Yup that is who I got mine from. They have the drawings from the model number and the new tank was exactly the same as the old and was done fairly quick. I did try to go through Catalina factory but they weren't able to come up with the same size tank for some reason.
Oct 5, 2010
322
Catalina 30 mkII St. Augustine
When you noticed you had a leak, was it a slow leak and you smelled diesel in the salon or did you see diesel floating on top of bilge water or did it just let lose and you had an environmental disaster on your hands?
Dec 14, 2013
3
Catalina 30 MKIII Middle River, MD
I had the same problem with our aluminum tank along the port seam. Removed the tank and fuel and took it to a welder who pressurize the tank and then rewelded the leaks. $100 for job.
BigPie
Apr 5, 2014
3
catalina 30 channel islands harbor
I had the same tank with a micro leak I could smell only in rough seas. I replaced the tank with a plastic tank by Tempo that holds 11 gallons. It fits in great and costs about 125. There are hold downs that can be purchased with the tank. I carry a 5 gal can on long island trips. It was a perfect solution.
Jun 5, 2004
241
Catalina 30 MkII Foss Harbor Marina, Tacoma, WA
...after reading all these I'd go with welding & while your at it have them cut in an inspection port...my '90 MkII doesn't have one.
Jan 6, 2010
1,520
PDA,
I had a leak bottom center in my aluminum tank several years ago. I made a 6" x 6" access plate & took the tank to be repaired. But now, I can quickly inspect & easily clean my tank.
However, this brings up another point, mainly what caused the leak. There was a bonding wire attached to a tang on my tank top. Here we go, stray current & aluminum don't mix. The bonding wire is used to dissipate any static charge when filling the tank. On the downside, all your bonding/grounding probably passes thru your engine ground, then along the shaft & into the water. If nearby boats are running electrical systems, this can cause this stray current to enter your system and affect noble materials such as aluminum. This is called Electrolytic Corrosion.
see http://www.ask.com/question/what-is-electrolytic-corrosion.
I removed the bonding wire from my tank tang & added an alligator clip. When fueling, I attach this clip, otherwise no connection to my tank. Let me know if a bonding wire is attached & the hole/s are located center bottom of your tank.
CR
Feb 26, 2008
603
Catalina 30 Marathon, FL
PDA,
CR
Ron, you got me thinking. The last time I filled up at a fuel dock was my trip down the Chesapeake when we were motoring 12 hours a day - either no wind or thunderstorms on that trip.
At a 1/2 gallon an hour and 10 minutes motoring out to the bay I just top her off occasionally with a 5 gallon jug.
Drives the power boat guys on my dock crazy :D
