Is this thing even worth having? It was on my boat when I bought it. It displays only volts, which tells me very little unless the battery is badly depleted ... right?
it can tell you if your battery is charging.... it can tell you the current state of charge left in the battery.... it can tell you if you are approaching the 50% limit of depletion for maintaining battery longevity.. if you care.Is this thing even worth having?
only good when your battery is in a resting state which could be quite a while after all loads are removed.Print and stick this next to it and you're golden.
...and after all charging sources are removed.only good when your battery is in a resting state which could be quite a while after all loads are removed.
Excellent video, Greg, very informative! I will definitely want a meter like that in the future.
So, don't keep me in suspense: what's the OTHER thing you and your better half couldn't live without?? You never did say!
Both totally correct....and after all charging sources are removed.
A sophisticated battery monitor, capable of tracking Amp-hour load, Amp-hours used, and voltage is well worth the cost.
It has nothing to do with boat size. A voltmeter simply is not an accurate way to measure battery capacity on any boat. You apply a load the meter will go down. A charging source will make it go up. Remove any load and charging source, wait overnight and it may be close. Maybe if you keep your boat at a mooring and you check it when you first arrive assuming you have no charging source and something like an automatic bilge pump had not be running recently.Both totally correct. But guys, it's a 22 foot boat! A simple analog DC voltmeter was standard equipment on all of our 35+ foot boats. Surely the same (in digital no less!) will suffice for the time being on his Catalina 22.
This is all very temperature dependent. At 80F the rest is normally 12-24 hours for an accurate reading. At 30F I have had batteries sit at well beyond full for many WEEKS before the surface charge burns off.But wait a second, not as easy as reading a chart. The same battery with the same estate of chart can give you different voltage readings. The closest voltage reading to reality can be obtained when the battery is at rest for at least 2+ hours.
