This may sound far fetched (I've seen pictures with smaller boats), but I would like to lower the bow with the crank on the trailer, build a stand under the stern (4 x 4 post and 2 x 4 rails), raise the bow high enough (it has to go up about 8 inches for the uprights to clear and may have to use additional jack) to build a stand out of 6 x 6 post and crosspiece 10' wide, enough to pull the trailer out. I will also have side braces out of 4 x 4 posts and 2 x 4 rails. As best I can figure, the full weight will not be on the front stand until I lower the front of the trailer. I will not be able to get shoring under the keel until the trailer is out. So, in addition to pros, cons, tips and/or advice, my question is, will the 10' span of the 6 x 6 hold the weight of the 1981 27' Hunter until I can get the shoring under the keel? Am I crazy for even considering this?
I added a couple of pictures that I found. Would have side braces in addition...
