Great Lakes sailors, the thaw is just about to happen
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
Oops my bad. Have y'all ever had this kind of winter were the large Great Lakes are freezing solid? Please keep all that melt up there, I got a feeling the flooding is going to be really horrible this year.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Don't worry about flooding from the lakes themselves, we could use a couple of extra feet of water. It's the streams and rivers that willbe the problem if everything thaws at once. The lakes have been low for several years.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
Having lived and sailed in Michigan for the past decade, I've found it best not to think about spring. Just keep your head down and do your job, until it ends. Natives tell me that this weather is typical of when they were kids. We all just got used to the slow global warming effect over the past decade, and this year is the throw-back. Doug is right that we could use several feet of lake level in the Michigan-Huron system. The lack of lake ice for the past decade is one of the reasons for the low levels. You salt water people may have to worry about tide tables, but it's low tide here year-round.
RECESS
Dec 20, 2003
1,509
I hope y'all get your levels back after this winter. I do not know how you sailors make it with your boats on the hard for so long? I would have to do a bunch of projects in a heated boat just to keep my sanity.
Aug 22, 2011
1,113
:kick:
Beneteau 323 Annapolis MD
Baltimore just had a new record low of 4 degrees. That record was set 141 years ago. Global Warming? Oh, bring it on !
Aug 20, 2010
1,399
Oday 27 Oak Orchard
Just to correct a few issues, this isn't a good old fachioned winter that the senile seem to remember. Lake ice has been tracked since 1963 and only three previous times has the ice cover exceeded 90%. This year we are at 95% which is a record never before seen. This is what I had up on another thread from Jim Cantore of The Weather Channel and the NWS. We had -5 this morning which is about 35 degrees below normal. On the global climate change, this is exactly the type of strange weather we can expect. With increased heating along the equator and tropical regions the rising air creates a vacuum that sucks the polar air southward and the warm air is transported above to the poles resulting in their warming and ice melt. The huge convection current in the sky so to speak. Not much fun for any of us unfortunately. Our sanity long ago disappeared. No sane person would live in this frozen eigth circle of hell.
Nov 25, 2013
14
Oday Daysailer I Lakeville, NY
Global weather is a system and like any other system, the more input / the more output. Dump heat energy into the atmosphere and watch the frequency and amplitude increase. More frequent, larger storms and the shift in the Gulf Stream which brings the cold farther south and ends up pounding the British Isles. We haven't seen the end of the longer cold snaps and drought in the southwest.
Oct 10, 2009
1,097
Catalina 27 3657 Lake Monroe
Paraphrasing a great old quote from Rogers Hornsby:
People ask me what I do in winter when there's no sailing. I'll tell you what I do. I stare out the window and wait for spring.
Johann
Jun 3, 2004
578
Leopard 39 Pensacola
Nonsense. There is no vertical airmass circulation from increased equatorial heating or any other cause. Coriolis forces dominate and would rip any such current apart before it could get started.
Johann
Jun 3, 2004
578
From the link:
"Contrary to the impression given in the simplified diagram, the vast bulk of the vertical motion occurs in the Hadley cell"
"It is a closed circulation loop, which begins at the equator with warm, moist air lifted aloft in equatorial low pressure areas (the Intertropical Convergence Zone, ITCZ) to the tropopause and carried poleward. At about 30°N/S latitude, it descends in a high pressure area."
Dec 27, 2005
500
Hunter 36 Chicago
They usually start putting the mooring buoys in the harbors around mid march. Probably be sometime in April before the ice melts at this rate. Just hope it doesn't delay getting my boat in the water. Lived in Chicago for over 20 years and never shoveled this much snow.
Feb 16, 2011
227
Macgregor 26X Michigan City, IN
Here's another rumor: Because of the higher than normal tempts in the western pacific pushing the air masses around the US west coast, the artic cold air is being forced into the midwest/east coast. ;)
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
So you are contending that if it is cold in Baltimore then the rest of the planet is cold as well?
