- Jul 21, 2013
- 333
Are there any tips in starting an EFI motor that has been asleep for couple of years?
I have cleaned the fuel delivery path, new hoses, new fuel pump in vst. Will check the rail pressure after I put it together and it will be ready to start.
Motor cranks, new spark plugs, new thermostats. First attempt at starting failed, found a faulty fuel pump.
My concern is the dry cylinders and number of attempts to start while waiting for the fuel and oil to reach the cylinders. I might also be dealing with clogged fuel injectors, I will see that later.
