I have an 1995 H26 water ballast hunter. I've developed a leak when the sailboat is underway. Sitting at the dock, it doesn't leak. The Hunter people have suggested checking the centerboard mechanism for leak. I raised the table and slid the wooden inspection cover up and have found a steel plate. The plate is sealed in place with what appears to be 5200 sealer. The compression post goes through the plate and there are two Phillips head screws through a sleeve that is around the compression post. There is a 1 1/4 in bolt head going through the plate. Can I remove the ss plate to inspect for leaks without causing more problems? Other postings I have read indicate that the 1 1/4" is what secures the centerboard in place. Any other suggestions on where to check for leaks would be helpful. Under full sail, I take on about 1 gal of water per hour.
Thanks for your help,
Dave K
Dave K
