I have a deep keel sump, with now a diaphragm bilge pump remotely mounted. Long story of pump reconfiguring to original mfg specs, but one part of it I could not figure out any other solution except to put the float switch on a galvanized steel tang, as the bottom of the sump is inaccessible for planting screws.
So I mounted the switch to an L-shaped tang, and lowered it into the bilge, then secured it to the cabin sole wood frame. The setup works perfectly. Would like to have found a plastic or other inert material, but couldn't.
My concern is that the pickup is made of bronze, and is an inch away from the tang. Both are constantly wading in about a half inch of brackish water at the bottom of the sump. Is this a setup for corrosion? Would attaching a zinc to the tang help?
I don't care about the tang replacement cost. It's a $5 piece of galvanized steel from the hardware store. But it's a pain to install, and I would like it not to covertly break, rendering the switch inop.
Thank you
Thank you
