I started this last weekend and hillbilly'd the line through two horn cleats, one on the boom and one on the mast. First picture.
I was sort of scared to drill the boom and mast to add the cheek block and eyelet I needed for the final and proper installation. After talking with some people I dove in and it was easy. I removed the cleat on the boom use one of the old hole and drilled a new one and boom the cheek block was installed on the boom. Then the installation of the fairlead eyelet with a center punch and a sharp drill but and some stainless steel screws and I was done. I re-routed the line and took her out for a sail and it was so easy to put a reef in and shake it out all from the cockpit.
For anyone hesitant don't be. Just take your time, use a center punch and sharp drill bit and have a plan. All in all a pretty inexpensive and worthwhile project.
